Turbometer
SGT
Tilmeldt: 3. jun 2004, 19:53
Turbometer
5. dec 2020, 18:31
Kan man umiddelbart montere et instrument med turbometer i en 9-5 lavtrykker?
Der er gået en pære og vil da i samme omgang gerne have turbometer i, er det bare plug n play?
Søren
SAAB är bra!
Re: Turbometer
6. dec 2020, 07:47
Det er ikke bare plug and play at skifte instrument.
Det nye instrument skal programmers for at passe til bilen,
og derefter skal startspærren programmeres, da instrumentet er en del af startspærre systemet.
Og man kan kun ændre km. tallet op ikke ned.
For at få måleren til at virke så kræver det nogle ekstra steps.
What i have is a 1999 9-5 2.0 B205E (European version). I want to put in a MIU from 2000 9-5 B235R (European) with a "boost" gauge. From what i've gathered, these steps apply:
1. Install the new MIU in the car;
2. Connect Tech2, tell it the car is B205E;
3. Go to DICE settings, change the 8th digit of the VIN to G
4. Exit programming, connect Tech2 again, tell it the car now is whatever it is after the second step;
5. Go to MIU settings, perform a spare parts programming
6. Go to DICE settings, change back the VIN number to the original;
7. Exit programming, connect Tech2 again, tell it the car is now the original;
8. Go to Diagnostics->Body->TWICE->Programming->Programming Immobilizer (or Diagnostics->Body->TWICE->Immobilizer, depending on Tech2 software);
9. Delete the fault code P1460;
10. Everything is working again with the addition of a "boost" gauge.
Om det er besværet værd det er tvivlsomt, dan den ikke viser tryk, men indsuget luftmasse.
SGT
Re: Turbometer
6. dec 2020, 21:20
Tak Morten
Det lyder som en besværlig omgang at skifte ud, så vil nøjes med pære skift ved lejlighed
Mvh Søren
SAAB är bra!
