Ang. hvilke olie Saab påfylder bilerne.
: 16. sep 2005, 10:43
Vi har diskuteret et par gange, hvad Saab fylder på bilerne fra fabrikken. Nu har jeg fundet et teknisk dokument fra Saab, der tydeligt understreger at det er Mobil 1 0W-40:
"9-3 Sport Sedan Service Intervals/Requirements: Requires Full Synthetic oil which meets GM-LL-A-025 specification
The Saab 9-3 Sport Sedan enters a new level of maintenance intervals and requirements. Service intervals fall under main categories: Intermediate and Main Service interval. A message on SID indicates to the owner when either service is required.
MAIN SERVICE interval is based entirely on mileage driven: 30,000; 60,000 and 90,000 miles.
INTERMEDIATE SERVICE is set by an algorithm that determines when service is required. Miles driven, crankshaft revolutions, number of starts/cold starts, ambient temperatures, speed and engine temperature are among the measurements used to compute the interval with the TIME FOR SERVICE message being set between 8,000 and a maximum of 15,000 miles. If the mileage interval is not met, the message will be set at 2 years.
NOTE: The actual oil condition is NOT measured, only the above calculations performed.
It is important to note that this computation is based on the use of fully-synthetic oil which meets GM-LL-A-025 specification. This is a specification that is currently not commonly found in the US. The only oils that are readily available that meet this specification are Mobile 0W40 SuperSyn and Saab 0W30 Turbo Long-Life Fully Synthetic oil.
Saab Fully Synthetic Turbo oil is available under the following part numbers:
12 799 131 = 4 liter container
12 799 130 = 1 liter container
If an oil of lesser quality is used, the algorithm will be incorrect and severe engine problems may occur."
Læg mærket til afsnittet med fed skrift. Hér står det sort på hvidt at Mobil 1 0W-40 SuperSyn den eneste olie der opfylder de af GM (Saab) fastsatte specifikationer, sammen med Saab 0W-30 Turbo Long-Life olie, der benyttes i USA.
: 19. sep 2005, 22:18
af PoulDue
Er Mobil1 = superSyn ?
: 20. sep 2005, 18:56
Hej Poul.
Jep, som der også står i teksten. ;)
: 20. sep 2005, 21:16
af PoulDue
Hmm så har du bare glemt 1'tallet?
: 21. sep 2005, 18:18
Poul.
Nope, Saab har. ;)
Desuden kan du kun få Mobil 1 som 0W-40. ;)
: 21. sep 2005, 20:48
af Aresdk
Så er det jo godt der er Mobil1 0W-40 i sumpen :)
: 21. sep 2005, 23:17
af PoulDue
Nul, man kan også få 5W-50, check din nyeste H N reklame.
: 22. sep 2005, 07:53
Poul.
Ja, det har man kunnet i mange år. Men nu er det 0W-40 der tæller....
