Jeg faldt lige over denne artikel omkring den nye 9-3 Aero med V6 Turbo.
Og med et tryk på kun 0,6 bar må der være basis for endnu flere hypper.
Six Cylinder Turbo Power gives
Saab 9-3 Aero Class-leading Appeal
Unique offer in segment, more torque than other six cylinder gasolineengines
Saab 9-3 Aero 2.8V6 Turbo fastest-ever Saab
First gasoline V6 designed from start for Saab's turbochargedapplication
Light, compact, all-aluminum construction
Twin-scroll turbocharger for smooth response
Variable cam phasing for improved breathing
Stainless steel exhaust manifolds for lower cold-start emissions
Sinter-forged connecting rods for extra strength
Tuned twin exhaust for sporty engine note
The Saab 9-3 Sport Sedan Aero with its new 2.8V6 Turbo engine is, quite simply, the fastest accelerating car ever to carry the Saab badge. It represents the culmination of almost 30 years' experience from Saab as acknowledged leaders in the art of turbocharging.
For the first time, Saab customers will be able to enjoy the combined benefits of turbocharged power and six cylinder refinement in a purpose-built package. With massive pulling power (350 Nm) spread widely across the engine's speed range, the 250 bhp/184 kW 2.8V6 Turbo generates more torque than any other six cylinder gasoline engine in the Saab 9-3 segment.
Saab Automobile Powertrain's expert knowledge and experience of turbocharging is recognized by its role as a Center of Expertise within General Motors for the development of turbocharged gasoline engines. The Swedish engineers were therefore closely involved during the conceptual design and development of GM's new global V6 engine architecture, ensuring it included the possibility of a turbocharged application.
Sophisticated technology
The 2.8V6 Turbo has a 60º vee-angle between its cylinder banks for perfect balance and combines excellent multi-valve refinement with outstanding performance. The all aluminum construction provides a light and compact architecture, well suited to its transverse, front-wheel-drive installation in the Saab 9-3 Aero.
The cylinder heads, each with double chain-driven overhead camshafts operating four valves per cylinder, are of high specification aluminum and unique to this turbocharged variant. The design ensures enhanced heat resistance under 85 bar cylinder pressures, as well as minimum maintenance costs.
Also unique are pistons with hard anodized ring grooves for durability and under-skirt oil jet cooling, together with steel con-rods that are strengthened by sinter-forging, a process that involves molding metal in a powered form. The exhaust valves are filled with sodium to further enhance cooling. The cylinders have cast iron liners and a bore/stoke of 89.00 / 74.8 mm.
For improved engine breathing, variable cam phasing on the inlet side is electronically controlled and hydraulically actuated, allowing continuously variable adjustment through 50º of crankshaft rotation. On the road, this translates to a more flexible power delivery and better fuel economy under different engine loads.
A die-cast aluminum oil sump is designed to increase structural stiffness and the strong, four-bearing crankshaft is made from micro-alloy forged steel, a specification more commonly seen in competition performance or diesel engines.
The twin-scroll, water-cooled Mitsubishi TDO4-15TK turbocharger, operates at 0.6 bar maximum boost with intercooling and an integral by-pass valve. It is mounted centrally above the transmission and fed by both banks of cylinders. The use of two separate inlet tracts, one for each cylinder bank, separates the exhaust gas pulses, improving gas flow, reducing energy losses and raising turbocharger efficiency. The turbine wheel is made from a special high-grade steel alloy, commonly used in the turbocharged engines of world championship rally cars, which is resistant to erosion, cracking and creeping under high temperatures and centrifugal forces.
Also unique are double-skin exhaust manifolds, which are hydroformed with stainless steel liners to improve cold start emissions by minimizing heat absorption to the manifold. Air injection into each manifold for up to 30 seconds after a cold start also helps the central pre-catalyst, positioned upstream of the main catalytic converter, achieve 'light off', its effective working temperature, as early as possible.
Smart engine management
The 32-bit engine management system, with software calibrated specifically for the Saab 9-3 application, utilizes a torque-based engine control strategy and direct coil-over-plug ignition with a robust engine-mounted control unit. Ignition timing, fuel injection, turbo boost pressure, air mass measurement and the throttle setting are all key engine functions controlled by the software.
The sophisticated control strategy is designed to deliver smooth performance in all driving conditions. The system works with the vehicle’s transmission to modulate torque, providing stirring performance and excellent engine response. The system can also limit torque in low-traction conditions, helping provide confident, sure-footed driving. Variable fuel pressure further contributes to smooth idle and driving characteristics.
For driving comfort, control of the electronic throttle through the movement of the accelerator pedal is programmed to be sensitive to different driving conditions, with greater pedal movement introduced at lower vehicle speeds, such as when maneuvering or parking. At low engine speeds, the engine control system also brings the turbo in quickly by momentarily opening the throttle slightly more than requested by the driver.
On the road the new 9-3 Aero 2.8V6 Turbo packs a formidable punch and the driver will also immediately appreciate the smooth power delivery, like an iron first in a velvet glove. Apart from the boost gauge in the dashboard, the only clue to the presence of a turbocharger is an uncannily effortless rate of acceleration.
Pick-up from tick-over at just 720 rpm is instant, due to the engine's relatively large multi-cylinder capacity. At about 1,000 rpm, the turbo begins to build a massive wall of torque that is already in place by the time the tachometer swings through 2,000 rpm. It endows the 9-3 Aero with a level of performance never before seen in a Saab car.
Maximum torque is generated all the way from 2,000 rpm to 4,500 rpm, with 90 per cent of this value available at an exceptionally low 1,500 rpm. Careful programming of the engine management software means that under a full throttle load, from take-off or low engine speeds, 90 per cent of maximum acceleration is delivered within one second.
The zero to 100 kph dash is accomplished in just 6.9 seconds, but in-gear acceleration provides even more impressive evidence of this engine's outstanding elasticity. In top gear, the transition from 80 to 120 kph can be accomplished in just 8.3 seconds, a figure that places the 9-3 Aero among the very best in its class.
The fun-to-drive nature of this performance is also matched by an exhilarating engine note that can be heard inside and outside the car. This has been achieved by tuning the twin sports exhausts downstream of the main catalyst. It gives the new Saab 9-3 Aero a distinctive aural character in keeping with its position as the sporting flagship of the range.
The engine is offered with a choice of six-speed manual or automatic transmissions. The close-ratio manual gearbox includes duel output shafts to reduce transmission vibration, together with a dual mass flywheel this ensures smooth and refined performance.
The 'smart' Asin AW automatic transmission is adaptive to driver usage patterns and prevailing road conditions. It can sense changes in engine performance, engine load, road gradient and altitude, quickly finding the right gear without an irritating 'hunting'.
For closer driver involvement, Saab Sentronic, a sequential manual gearshift, is also included. When the shift lever is moved across the gate to ‘manual’ Sentronic mode, ‘up’ and ‘down’ changes can be made with full lock-up in 3/4/5 or 6th gears. This process is taken a step further by the option of steering wheel buttons, which bring gear-shifting right to the fingertips of the driver.
Overall, the 2.8V6 Turbo generates class-leading levels of torque with a seamless, turbine-like power delivery. Itcombines the inherent advantages of a six-cylinder engine - refinement and a rapid throttle response - with the effortless, torque-boosting properties of turbocharging.
Saab 9-3 Sport Sedan Aero 2.8V6T:
Technical Specifications and Performance
2,792 cc. V6. Bore 89mm, Stroke 74.8mm
Aluminum cylinder heads and block.
2 x DOHC chain-driven, 24 valves. Variable valve timing (inlet)
Turbocharged, intercooled.
Max boost pressure, 0.6 bar
Compression ratio, 9.5:1
Bosch Motronic engine management.
Direct ignition, multi-point fuel injection, electronic throttle control
Max.power: 250 bhp (184 kW) @ 5,500 rpm
Max torque: 350 Nm @ 2,000 - 4,500 rpm
SAAB 9-3 Aero 2.8 Turbo V6
- LarsT
- LarsT
- LarsT
- turbosøren
Ja det er spændende sager, men hvad jeg ikke forstår er at din iflg. saab´s egne brochure er 7.3 sek. fra 0-100 og 245 kmh på toppen for 93 Aero sports combi med 4 hjulstræk??
For ikke at tale om sentronic udgaven som er hele 8.3 fra 0-100!
Det lyder da ikke umiddelbart særligt imponerende.
- rene
Det var dog en underlig artikel...den hurtigste Saab nogensinde?...de specifikationer der står kan en 9K aero da nemt stikke...
Men de der motorjournalister sidder nu heller ikke altid forrest i kanoen...på discovery's bilprogram sagde de engang at en saab kun kunne fåes med turbomotor...
Syns li'som der mangler noget i mit motorrum så...
- 9-5Aero
Hej Cerebrum.
Din tid må være i 4. gear. For 9-3 Aero er det i 5. gear (6. gear?).
- ttp
Mht. til at Saab kun kunne fås med turbo - var det ikke da man introducerede 9-3 eller evt. ng 900 at der var en periode hvor alle modeller var med turbo? Først senere kom der en fattigmands model
Aktuelt:
SAAB 9-3 SC 1.8t hirsch, my 2007
Tidligere biler:
SAAB 900 SET, NG 1995
SAAB 900i, 1987
SAAB 900GLi, 1984
SAAB 99L, 1978
Aktuelt:
Tidligere biler:
SAAB 900i, 1987
SAAB 900GLi, 1984
SAAB 99L, 1978
det er rigtig nok der var lige en 2-3 år hvor man kun kunne få saab med turbo. hvorfor skulle de dog også gå væk fra det igen.......
en anden ting, er der nogen der har kigget nærmere på opel sigma 2.3 V6 stationcar.... den minder lidt rigeligt om Saab 9-3 sports combi
- turbosøren
Det besynderlige er at V6 biturboen ikke er markant hurtigere end den nuværende 2,0 Aero. Spørgsmålet er om SAAB ikke underdriver for ikke at sætte salget af den nuværende AERO i stå??
- 9-5Aero
Søren.
Biturbo?? Nope Sir.....
- cv7000
- labr_dk
Ja - med mindre at det er lige som med den V6-er som Saab (undskyld, Opel) har leveret til Saab V6 modellen.
Den er væsentlig mere skrøbelig end Saab 4-cyl Turbo standard motoren - desværre !
Lars
Lars
